I am migrating two old AW installations to a new win10 home machine.
These two installations are versions 5.16.B04 Standard and 4.1.160506.
Both installs work without problems on win7. Another detail on the 5.16 install
is that I expected that on the first run, I have to logon with dspconcepts
user name and password. I did not get that far.
Note that part of the reason of installing to new machine is for support.
I am attaching two pictures on what I am seeing.
Thank you.
EE
![](https://dspconcepts.com/sites/default/files/aw_4_1_160506_fail_to_run_under_win_10.png)
![](https://dspconcepts.com/sites/default/files/aw_5_016_fail_to_run_under_win_10.png)
9:32am
Is this still an issue? I saw another post that indicated that you were able to start 5.16.B04.
In case you're still having problems, the second picture you posted suggests that the AWETalkToGUI.dll was not registered correctly on your machine. To remedy this, open a cmd prompt as administrator and navigate to '<AWE 5.16.B04 Install Folder>\Bin\win32-vc100-rel'. Once there, to re-register the .dll type 'regsvr32 AWETalkToGUI.dll'.
