I am using PRO AWE, windows 10, Matlab R2016A
If I put a router into the signal flow, then open the inspector, then delete the router, the inspector never goes away. If I try to close the inspector the I get an error on the command line stating that the inspector cannot be found. If I close awe the inspector stays. I cannot close Matlab. The only way to recover is Alt Ctl Del and kill Matlab.
4:18pm
I see identical behavior with my testing - thanks for pointing this out.
I'll put in a ticket to get this fixed.
