Hello DSPC
I want to surrender the signal flow created in AWE Designer to someone else.
I want to make some modules and subsystems uneditable and unviewable.
How can I do this?
Permissions settings can be parsed from aws and awj files.
Reusable Subsystem" was also parsable from a json file.
Is there any other way?
Best regards
How to Hide Edits in AWE Designer
          #1
7:18am
Hello naomichi_tsuduno_9939,
Please try using our compiled re-usable subsystem (CRUS) feature for this use-case.
2:55am
Thanks for the response Kevin.
I was able to create a protected module by using CRUS.
However, it seems that if the ObjectID is set for the module in the Subsystem before conversion, the contents can be checked by AWS even if CRUS is used.
It would be helpful if there is a note somewhere.
Thanks Naomichi.
3:06am
Yes, this is true. You may want to remove ObjectIDs within the CRUS subsystem. We can add this to the documentation.
