There are both AWE Designer and AWE MATLAB API MHz profiling possibilities. However, it is the average MHz profiling I mostly get. The peak profiling is only mentioned as a total number for the entire layout in one place. It is the peak profiling that tells us if we have a problem.
Example: I have a layout that takes 15% average on target but takes 20% peak. How can I find out what module(s) causes the peak fluctuations? I prefer MATLAB API.
Kind regards,
BOHR
11:36am
Hi Bohr,
Start by seeing whether the information under "Module Profile Type" in this article is of use. You will need to run several passes of profiling and then look to see which modules show the greatest variation. Is this helpful?
https://tinyurl.com/2ffxbs95
