Hi DSPC team,
https://documentation.dspconcepts.com/awe-designer/latest-version/preset...(8.D.3.2)PresetsinAudioWeaver-GeneratingapresetAWB
In the guide, the “presets generating” mentioned in the Presets section and the method introduced in External Handling — are these only available in the AWE Pro version?
In other words, apart from using methods like ParamSet and ArraySet, is there any other way to store and manage a complete set of presets?
For example, in different scenarios I might need to switch to another set of parameters in real time without changing the layout.
Is there any method that allows me to export only the presets (instead of generating all signal-flow information through Generate Target Files)?
