Release Notes
Audio Weaver® - Version 7.A.0.6
NOTABLE NEW-FEATURES AND IMPROVEMENTS
- Bugfixes with feature licensing when connected to a remote server.
- Remote Server connection freezing bug fixed
- Can now open files with File->Open while in tuning mode
- AWE Server audio file skip forward/backward feature fixed
- Bugfix with Audio Start/Stop on AWE Server
- Bugfixes in generated target files
- Bugfixes with RS232 connection
- Fix the issue when user open default layout is trying to generate target files the progress window never disappear.
- Fix the issue that couldn’t open module properties in Standard and STMicro
- Fix the issue on server that doesn't fail gracefully on launch if last session was connected to tcpip and connection is no longer available
- Fix the issue with awe_find_file.m that fails to find folders when directed to look for folders specifically
- Increase TCP timeout in Server .ini file
- Add warning message if there is a mismatch in sample rate
- Eliminate FileName in the Pin Build Properties since this functionality were disabled in AWE-7
- The argument isSMP in core argument was eliminated since only SMP multicore layouts are currently available
- Change dropdown option in `Change Connection` of AWE Server from `Ethernet` to `TCP/IP`
- Better error checking when audio devices don't start in native mode
- The properties Tools->Process Files will be available only in Native mode
- Canvas size now limited to 10 pages by 10 pages
NOTABLE NEW-FEATURES AND IMPROVEMENTS:
- Add new command for AWB to identify AWB version
- Add new Audio Weaver Tuning Command 'get_rate,<file>'
- Can now use File->Execute Script to execute AWBs on an embedded target
- Can now Profile Running Layout when connected to a Remote Server.
- Example .AWDs now included in all Designer deliverables
- Increased default Heap Sizes for native mode.
- New “isTunable” setting for modules. If set to no, inspector cannot be opened and tuned in realtime.
- New Generate Target Files dialog window with better descriptions of files
- Updated documentation for Designer
- Changed the way module’s ObjectID were generated
