Ok. Please follow these steps to turn on some logging so we can help you debug.
Shut down Designer completely. Open Server's INI file <Install Dir>\Bin\win32-vc100-rel\AWE_Server.ini and find:
[Logging]
; Turn text log off.
Enable=0
; Text log will be awelog.txt
LogPath=awelog.txt
; Special flags for extended logging - all off.
LogFlags=0
Change that to:
[Logging]
Enable=1
LogPath=awelog.txt
LogFlags=0
; Log Matlab commands and replies - default off.
MatlabLog=1
; Log Designer commands and replies - default off.
CommandLog=1
; Log User port - default off.
Server2Log=1
Server3Log=1
Server4Log=1
; Log target binary packets - default off.
PacketLog=1
Restart Designer and try to open your file again. In win32-vc100-rel/logs find several log files after the failure. Please ZIP them up and send them to us.
The logs didn't show any information about opening your file, which means that the load is failing in MATLAB code before any of our logging kicks in. This likely means that your .awd is corrupted. If you're comfortable sharing your design with us, we can take a look and see if there's anything we can find on our end.
9:29am
Do you get an error when you open the file? Which version of Designer are you using (Pro, Standard?).
9:36am
At the moment i am using the standard edition from STMicro (AWE_Designer_8.B.1.4.B_STMicro.exe).
It starts loading the file and then it stops without giving any messages.
10:12am
[Logging]
Enable=0
LogPath=awelog.txt
LogFlags=0
Change that to:
[Logging]
Enable=1
LogPath=awelog.txt
LogFlags=0
MatlabLog=1
CommandLog=1
Server2Log=1
Server3Log=1
Server4Log=1
PacketLog=1
3:38am
Hi Axel,
thank you so much for the help. Here you find the zip file!
Federico
10:50am
Hi Federico,
