Unable to access the page to download ST_Audioweaver for STM32F411
4 posts / 0 new
hari
Last seen: 5 months 1 week ago
Hey guys,
I want to use ST-Audioweaver for STM32F411 discovery board. My questions are-
1. Is the board supported?
2. I am unable to access the "dspconcepts.com/st" webpage to download ST-Audioweaver though logged in dspconcepts.com. It says access denied.
3. Is there any restrictions that only Keil U Vision should be the IDE for integration? I am using Atollic Truestudio as the IDE, so want to know if it can be used.
Please help me to sort these out. Thanks in advance!
Axel Nilsson
Last seen: 3 hours 45 min ago
Hi Hari,
The STMicro license agreement with DSP Concepts has expired and is currently being re-negotiated. This means that the free STMicro Designer licenses and STM32* BSP's have been removed from the downloads page. For the time being, you can get a 30-day trial license for the Standard edition of Designer. See this thread for details: https://dspconcepts.com/forums/audio-weaver-designer/554-awe-designer-st-edition-licensing-issue
To answer your other question:
Once the STMicro content is available again, you could use the STM32F407 BSP as a starting point to port to the STM32F411. The same AWE Core libraries will work on both targets, but you will have to update the integration code for the STM32F411 hardware.
We support Keil's uVision, IAR's Embedded Workbench for ARM, and the free SW4STM32 IDE's for the ST targets. I believe TrueStudio uses GCC, which means that it should be compatible with the SW4STM32 libraries, but we have not used TrueStudio internally so have not confirmed this.
hari
Thank you for your reply Axel. A small doubt.
Does this mean I will be unable to use the Audio weaver for any STM32 boards for now? As you mentioned in a thread in your reply, the trial version download page did not have any STM32 BSPs.
Axel Nilsson
The STMicro licenses have been extended to June 16, 2020, and all the STMicro content is back up on the downloads page:
https://dspconcepts.com/downloads
