I have AWE 30 day trial installed. I can run Sb Beamformer with MAXSNR and DVDR methods but when I try CVX method I get error "CVX is not installed". However CVX Professional is installed on my machine and I can use it from Matlab 2019b. How can I fix this so that I can use it from AWE Sb Beamformer?
Richard
12:49am
Hi Richard,
In standard version of Audio Weaver, the underlying Matlab framework is the mcr. Unfortunately, we cannot modify this MCR to include the cvx libraries for many reasons, the main being we don't have distribution rights for it. Audio Weaver Pro version is run in a real Matlab environment, and would easily honor the Matlab path with the included cvx tool that you have. I don't know if the MCR path is editable as most things are locked down.
3:16pm
Hi Richard, the trial version (and the Standard) version of Audio Weaver Designer are compiled Matlab applications. We don't have distribution rights for the CVX library and this code is not available in the Standard version. This is a bug - we should only show CVX in the Pro version.
