I have AWE ST Edition and am running the DSPC/Sensory/ST example code on an STM32H747 Disco board.
However I have not been able to connect AWE Server to the dev kit.
Instead I get "Target is not ST, but you are only licensed for ST".
Has anyone seen this before, or know of possible areas to investigate?
I am not sure how AWE actually verifies the target is indeed an ST part...
Regards.
12:24pm
Hello johndoe,
Audio Weaver Designer ST Edition will only work with certain ST BSPs, either obtained from ST Micro directly or on our website Downloads page. If you're not using one of theses "special" designated ST BSPs for your embedded EVK, you will get this error.
9:35am
Hi Kevin,
The package was supplied by ST directly.
I've reached out to them to discuss as well.
Could there be other reasons?
Regards
9:35am
Hi Kevin,
Regards
2:11pm
Hello johndoe,
The only other reason would be if the EVK itself needs to be provided by ST (there are special ST parts/EVKs that lock to ST Designer). It depends on the build flags of the AWECore library, but I'm not sure what library/BSP you are using. If you'd like to include me in your correspondence with ST, it's possible we could get to the bottom of this quicker. I believe you have my email already.
