I am trying to create a Interpreted Module. In the documentation at: https://documentation.dspconcepts.com/space/DOCHUB/2748822025/Custom+Mod..., there is a section saying that some custom module functions are supported, like the "preBuildFunc".
I have tried to create a new interpreted module with only the preBuildFunc as a custom function. I have put it in a separated file and linked it using: "M.preBuildFunc=@preBuildFunc;"
Setting M.isInterpreted = 1 works in the AWE 8.C.2.5.A Pro version (even shows the tag "interpreted" in the module name). But it doesn't work in theAWE Designer 8.D.1.1 Standard version. When I try to insert the module into the canvas I get the following error message:
"Adding module failed: Previously accessible file 'C:\DSP Concepts\AWE Designer 8.D.1.1 Standard\CustomModule\matlab\preBuildFunc.m' is now inaccessible."
If I do not include the preBuildFunc, the AWE Designer accepts my custom module.
Is there anything else that I should set to make the use of preBuildFunc in the matlab module script?
Thanks in advancce,
Rodrigo
3:03pm
Hi Rodrigo,
We are in the process of updating the DSP Concepts' documentation hub (https://documentation.dspconcepts.com/space/DOCHUB/2748809243/Welcome) to include an application note on Interpreted Modules. In the meantime, I've attached a working draft of this app note here:
interpreted_modules_application_note.pdf
. Please review and let us know if you are able to resolve your issue.
Michael
5:13am
Hi Michael,
many thanks! The PDF helped a lot. Our issue was solved by the item 2:. "Add spaces around equals signs for assignment functions (see lines 34-37 in Figure 1)".
Best,
Rodrigo
