Want to use Spotify as audio source for AW and output to a Bluetooth Speaker.
All this on the same PC, is this possible?
Have only managed to select line in or local files as audio source.
I''m doing this now by using an external client (mobile phone) running Spotify -> line in to PC/AW -> BT Speaker., but would like to skip the phone and do all this on the same PC.
11:14am
I'd give Virtual Audio Cable a try.
Virtual Audio Cable (VAC) - connect audio applications, route and mix sounds (muzychenko.net)
Let me know if it works!
4:22am
Ah, had totally forgotten about this option. Works like a charm.
https://jackaudio.org/ should also be useful for this.
