After deleting .dll file of a custom module, AWE Designer seem to hold the custom module on the palette un Third Party. When drag and drop it on sketch it highlight is in red which I assume its because it can't find the .dll anymore.
Is there a way to remove them from the palette as well?
2:15pm
You'll have to also delete the module's folder from the module path.
In designer, File->Set Module Path.
2:25pm
It worked! Thank you!
