Attached a simple design with 3 LR filters.
I'm trying to use the measurement toot to create a combined frequency response, but every time I get the error message shown.
Please advise how I can correct it.
Best regards,
Yair
Best regards,
Yair
4:03pm
Hi Yair,
I'm not sure what is going on. Which version of Audio Weaver are you using?
If I open your AWD I can reproduce the issue in 8.2025.2 Standard. If I recreate it from scratch (or partially, as shown) it works fine.
4:34pm
I think I found the reason. The start (and end) markers for the measurement must be on the same wire that do to/from the filter module. When I modified the design, it worked.
Interesting.... maybe you should add it to the manual.
Thanks for the help,
Yair
