I'm currently researching AVAS algorithm.I hava a base AWE project which developed on Standard AVAS_v10c.
I can build this project succeed, but it can't make a sound. I think may be some compoent doesn't work well, just like WavePlayerFlash.
WavePlayerFlash will load wav file form flash, now i want to use AWE default wav file, so which compoent can in place of WavePlayerFlash?
2:16pm
Hi chao_cui_15902,
Please let me know whether you are trying to run your AWD in Native mode or on an embedded device.
I have tried opening your AWD in the most recent release 8.2025.2.A and it is missing CANOpv5 and WavePlayerFlash, which suggests that you are using an older version of AWE Designer. I've found version AVAS_v10c and it is our previous generation AWE6, which is around 3 years old.
Can you give me a bit more information about what you are doing? i.e. are you developing a new layout, or are you trying to update or maintain an existing design?
Also please review our application notes on the various wave players available in the current AWE8 Sound Design Module pack.
Wave Player
Sound Design Modules
Sound Design Pack's Wave Player Modules with Embedded Examples
10:47pm
Hi Gary,
Thanks for your reply.
I am trying to update this AWD file in 8.2025.2.A. I found that 8.2025.2.A doesn't have CANOpv5 and WavePlayerFlash .
So I wan't to find other component in place of them. Can you give me some advice?
At the same time, I use AVAS_v10c to run this project , it build succeesful, but doesn't make a sound. I use native mode.
Best wishes!
