HI,
I just would like to know what is max number of pin out from interleave and de-interleave module ?
I know its sounds bit odd but in our of our stress test we are plan to handle 120Ch in and out in awe_designer, but when i pull this module in the layour]t this has limited my Deinterleave pins to 100 as max. just would like to know is this a limitation from DSP concepts or are there any alternative do i need to follow ?
BR
/Harish
10:36am
Hello Harish,
I was able to route 120 channels to a deinterleave module successfully using 8.D.2.6 after setting the numOut variable to 120 and confirming 120 channels were being sent as an input. Are you sure 120 channels are being fed to the deinterleave module?
