I'm using the latest version of AW Standard (8.2025.20 , and when I use "Tools/Process Files", Audioweaver is hanging up, even after waiting over 5 minutes. Hitting cancel doesn't close window. I've tried restarting my machine and it still occurs. Any suggestions on how to overcome this? This happens with even just one small wav file being selected. Thank you for your assistance.
12:14pm
Hi JasonD,
How did you create the WAV file? There may be some incompatibility that is not handled properly. It would be helpful if you ran the WAV file through AI such as chatGPT to identify the labeled chunks and other properties. We've found that WAV files exported from Audacity usually work well.
Gary W.
