Recently on my Windows PC (Windows 11 for arm 64), old version 8.D.2.6 of AWE Designer (which I used for some years) fails to launch.
Right after AWE Server boots, it disappears and AWE Designer emits following error:
So I updated to the latest one, 8.2025.3, and am facing awb file compatibility issue.
With my AWECoreOS library implementation,
attached 2MicTalkTo_0_0_4.0 loads successfully (which was built with the old AWE designer),
but attached 2MicTalkTo_0_0_4.1 cannot be loaded (which was built using the latest AWE designer).
The error message is as follows:
The layout .../AWECoreOS/Designs/2MicTalkTo_0_0_4.1.awb downloaded unsuccessfully at position 1 with error = Unknown error -39
AWECoreOS version info is as follows:
AWECore cortexa Build
Built on: Thu Nov 07 15:41:03 EST 2024
Build name: release.awe.cortexa-2181
Built from: awecore-common
Version: AC-8.D.8_ACOS-8.B.18
SHA: ed4bad1
AWECore CortexA cortexa Build
Built on: Thu Nov 07 15:41:07 EST 2024
Built from: awecore-cortexa
Version: v15
SHA: db3c4f7
cortexa Build -- Toolchain Info: [aarch64-gcc-arm-10.2]
Built on: Thu Nov 07 15:41:10 EST 2024
Built from: dspc-cmake-toolchains
Version: master
SHA: 56770da
Recipe File Used: AC-8.D.8_ACOS-8.B.18_VUI_Prod.recipe
Built on: Thu Nov 07 15:41:13 EST 2024
Built from: awecore-recipes
Version: master
SHA: fdac07f
AWECore Build -- Module Set: awe-mod-dspc-vui
Built on: Thu Nov 07 15:41:16 EST 2024
Built from: awe-mod-dspc-vui
Version: VUI-1.2.13
SHA: 8c7959e
Could anyone help resolving my issue?
Best regards,
Takashi
