According to the help file for awe_version MATLAB function it should return 8 numbers. As seen on the attached picture it only returns 7.
Our code uses these 8 numbers so it must have been working in an earlier version.
12:05pm
It looks like the "connectionStruct" version reporting from awe_version() was removed in version 8.C.2.2 as getting this information was very slow. So, at the moment, the help documentation is out of date.
You may also wish to try the "target_get_info()" MATLAB function if your goal is to distinguish which version of AWE you are using.
I hope this information is useful to you.
5:24am
Yes Gary. Thanks.
