Hello
I need some sub millisecond delay so when I place this block and connect it up it is converting the 192KHz stereo input with a block size of 64 down to a 48KHz mono output with a block size of 32 ??? How is this supposed to work or does it only work with a mono source ?
Regards
David
4:46am
OK when I run it or click on "Propagate changes" it it sorts itself out. Is this intentional or a bug during design time ?
regards
David
10:21am
Hi David,
This is the intentional operation of Designer. The GUI doesn't try to figure out the inputs to a module until the user clicks Propagate Changes or tries to run the layout.
