(Using Audio Weaver 6.17.B03 Standard)
I am able to build & run layouts on a SHARC target, but when I try to generate any target files, I see this error pop-up:
Note: If I open the same .awd file in Audio Weaver 6.17.B02.RC2 Standard, I am able to generate target files.
11:28am
Hi Patrick,
We did add a piece of code in between B02 and B03 that you seem to be tripping up. It is not clear yet what conditions could be causing this failure, since it should only happen if the layout is not buildable, but you are able to build and run on the target.
We will keep looking into this and get back to you when we have a better understanding of why this error is happening.
2:48pm
Patrick,
Can you tell us which target files you're trying to generate? Is it more than just .aws, and have you tried checking off different files to see if continue to get the error?
Also, is this for just one .awd or all the layouts that you've tried?
Thanks for any info you can provide to help us isolate the cause.
Axel
