I have build a AWE module where I can tune a parameter (INT array) from the tuning interface (TCP/IP).
However, it seems not to be saving the array after changes.
If I stop the AWE server and resume it again, the INT array will not reflect the tuning data received through TCP/IP.
Is there a way to add persistence to variable parameters of a custom module?
4:55pm
Hi Rodrigo,
I can try to help you troubleshoot this. It will be useful for me to know a bit more about your setup.
Which version of Audio Weaver are you using? What is the target platform where your custom module lives?
Can you please detail the sequence of steps you are taking to try to tune the module over TCP/IP? When you make the tuning change, does the module update correctly and the data processed by the module reflects the array update but then the change does not persist when stopping/restarting Audio Weaver, or does the change not take affect at all?
Michael
4:34am
Hi Michael,
I am using the AWE 8.C.1.3.B Pro version. We deploy for native (Windows app) and Sharc SC589.
I am able to connect to the server and send INT arrays. From inside my module, my SET function is called and I can read the new INT array. So, the module reflects the array update from TCP/IP. However, if I stop the server and start again, the last array update is lost. How can I make this be stored?
Rodrigo
5:35pm
Hi Rodrigo,
Thanks for the additional information.
When you stop the server and start again, are you also stopping and restarting the processing design or does the processing design continue running in the background and the server reattaches to the target?
If the processing continues running in the background, then it's expected that the array changes would persist and we will need to dig deeper.
If the processing design is stopped, then when you restart it Audio Weaver will re-perform the dynamic instantiation of your processing design; that is, it will resend a series of binary commands describing how to assemble and configure the design based on the design file. If you are using Designer to run the design file, then the Server will translate the parameter settings from the design into binary commands and the array changes should persist. If you are instead loading a binary design file (.awb) outside of Designer, then the array changes would not be saved in that binary file unless you save and update the file with that tuning adjustment.
I hope this helps you resolve this issue. Please let me know if you are still having difficulty getting the array changes to persist.
Michael
