construct instances error with RT685 EVK
5 posts / 0 new
glenne_4557
Last seen: 1 week 4 days ago
I have an RT685 EVK with 06/14/19 BSP Release with no changes.  The following sequence shows my problem:
  1. Set switches to up-up-down, reset board, flash BSP as-is from DSP Concepts and run.  Green led blinks at the proper rate.
  2. Connect Audio Weaver Server.  It properly identifies the board but the CPU % does not update.  I've verified it is continuously polling for profile values.
  3. Start Audio Weaver Designer, click Refresh Target Info.  It properly shows two RT685EVK Endpoints.
  4. Load a Design and press the Run button
Error: Server Command Failure: Command sent to server: 0, destroy, Server response: failed, construct instances error
Notes:
  1. If I rebuild the BSP with 'RUN_STANDALONE' Audio Weaver Server then shows continuously updating cpu% but Designer still gets the error shown above.
  2. If I return switches to down-up-up and reset, the board boots, leds blink but the behaviour is the same - Server Command Failure.
What am I missing or can I try to get this to work properly?
Chris Perry
Last seen: 3 weeks 4 days ago
The RT685EVK BSP using our newest AWECore-8 and requires a recent version of AWE_Server/Designer. What version of Designer are you running?
glenne_4557
IAR Embedded Workbench for ARM 8.40.1.21539
Shared components 8.3.2.5988
Audio Weaver Designer 7.A.0.8 Pro
Axel Nilsson
Last seen: 6 days 4 hours ago
Hi Glen.
You'll need an 8.x version of Designer to use the RT685 BSP. Someone from DSP Concepts will be in touch shortly.
glenne_4557
That fixed my problem.  Thanks!
