How does one use the frequency domain for playback processing? Are there any advantages/drawbacks to using this instead of time domain processing?
Disadvantages of doing processing in the frequency domain are:
Increased latency involved in the FFT/Windowing stage (8ms minimum using 256 blocksize, increasing with higher blocksize). Blocksize=256 Stopband Attenuation(dB) 1_31 32-45 46-59 60-73 74-87 88-102 Latency(samples) added 384 640 896 1152 1408 1664 Latency(ms) 8 13.3 18.7 24 29.3 34.67
Higher memory requirement
Possibly more setup when managing many frequency bins
Advantages of doing processing in the frequency domain are:
Less computations required
Higher resolution filterbanks/crossovers
Linear Phase
Constant, flat group delay
Sharper filter band edges.
I will attach an example system for further help soon.
filterbankeq.awd Here is the example file for the FilterbankEQ.
6:03pm
7:23pm
