Playback Processing in the Frequency Domain
3 posts / 0 new
DSPC_Peaston
Last seen: 1 day 20 hours ago
How does one use the frequency domain for playback processing? Are there any advantages/drawbacks to using this instead of time domain processing?
DSPC_Peaston
Disadvantages of doing processing in the frequency domain are:
Increased latency involved in the FFT/Windowing stage (8ms minimum using 256 blocksize, increasing with higher blocksize).
Blocksize=256
Stopband Attenuation(dB)
1_31
32-45
46-59
60-73
74-87
88-102
Latency(samples) added
384
640
896
1152
1408
1664
Latency(ms)
8
13.3
18.7
24
29.3
34.67
Higher memory requirement
Possibly more setup when managing many frequency bins
Advantages of doing processing in the frequency domain are:
Less computations required
Higher resolution filterbanks/crossovers
Linear Phase
Constant, flat group delay
Sharper filter band edges.
I will attach an example system for further help soon.
DSPC_Peaston
Binary Datafilterbankeq.awd
Here is the example file for the FilterbankEQ.
