audio module path
2 posts / 0 new
Darrel
Last seen: 1 month 3 weeks ago
audio module path
I am creating a custom module.  I am using AWE 6.18.02 Pro.  My OS is Windows 7.
In the doc "Module Developer's Guide" page 137 it states "7. Edit awe_init.m and update the audio module path."  Since awe_init.m is now a .p file it is impossible to edit this file.  Is the correct way to do this to go in to designer and add the path there?
Axel Nilsson
Last seen: 2 hours 28 min ago
Yes, Darrel. From Designer, go to 'File-> Set Module Path' and add your new module.
This can also be done programmatically in MATLAB with the 'add_module_path' function.
There is also a file 'awe_my_init.m' that gets called by the encrypted awe_init.m function. You can add any custom setup code to this file to get called everytime you run awe_init or awe_designer.
