AWE unable to connect to the AMLogic A113x Development board
4 posts / 0 new
Mike.delsanto_2443
Last seen: 9 months 3 weeks ago
Having difficulty connecting to the AMLogic 113x Development board using Ethernet.  The board connects for 5 seconds and loses connection and the connection to the AWE server needs to be reset and then has the same issue.  We are unable to do any speaker tuning or Voice UI modifications.
Ramya
Last seen: 1 week 2 days ago
Hi Mike Delsanto,
      If you have connected through serial debugger to board you might have this problem. Try connecting to AMLogic hardware directly .
Ramya
Jie
Last seen: 2 weeks 3 days ago
Hi, I have encountered the very same problem by connecting AMlogic A113X board via wifi (TCI/IP), it connected for 1 second then dropped immediately.
Axel Nilsson
Last seen: 1 day 6 hours ago
You may be running into a TCP/IP timeout if the connection to the AMLogic board is slow. Try adjusting the timeout section in the <AWE Designer Dir>\Bin\win32-vc100-rel\AWE_Server.ini to increase the timeouts. See a sample configuration below:
[TimeOut]
TotalTimeoutTimeout=3000
TCPTimeout=2500
Let us know if you continue to have issues
