Having difficulty connecting to the AMLogic 113x Development board using Ethernet. The board connects for 5 seconds and loses connection and the connection to the AWE server needs to be reset and then has the same issue. We are unable to do any speaker tuning or Voice UI modifications.
11:28am
Hi Mike Delsanto,
If you have connected through serial debugger to board you might have this problem. Try connecting to AMLogic hardware directly .
Ramya
12:57am
Hi, I have encountered the very same problem by connecting AMlogic A113X board via wifi (TCI/IP), it connected for 1 second then dropped immediately.
11:30am
You may be running into a TCP/IP timeout if the connection to the AMLogic board is slow. Try adjusting the timeout section in the <AWE Designer Dir>\Bin\win32-vc100-rel\AWE_Server.ini to increase the timeouts. See a sample configuration below:
[TimeOut]
TotalTimeoutTimeout=3000
TCPTimeout=2500
Let us know if you continue to have issues
6:50am
the sticks in A2 and B2 as recommended. I was also able to further tune it to 6000C34 and some tighter timings across the board at 1.325v VDD/Q/QTX. 12-28
https://gbplus.net/download-gbwhatsapp-apk/
