Hi Guys,
This is very new and very scary….I have the 69 Board.
I have to say from the start, I am totally confused. There seem to be a lot of programmes and I am not sure even if I have them all….
Audio Weaver STM32F769I Discovery Board User Guide.
I am on the bottom of page 9:
At this point the Audio Weaver Server can communicate with the board. To make sure
that the Audio Weaver Designer sees this change, click on the “Reconnect to Server”
button.
I have an Audio Weaver Error – not connected.
As you can image, getting to page 9 of the User Guide is bad….
Can you help??
I tried to follow all the steps and still it failed. Perhaps a video???
There should be a jpg of the error...but I have tried 4 times...cross fingers 5th will make it happen
Please ???
D
2:48am
<p>As much as I try I cannot attach a jpg of the error....</p>
3:12am
Hi Guys
(still not able to attach jpg’s)
Not sure what I did. It is totally confusing.
Somehow…I opened and closed STLink and Audio Weaver Designer: it and it then asked for my login???? Now the Audio Weaver Error is:
Wiring error at the top-level system
Module SYS_deint output pin out1 is not connected
Module SYS_inter input pin in1 is not connected
Module SYS_inter input pin in2 is not connected
I hope it makes some sense to someone…
Thank you
D
9:40am
Hi! Sorry for the confusion, but it definitely seems like you are on the right track. Yes, you are prompted for a login the first time you boot to verify your license.
To run an Audio Weaver layout, ALL pins must be connected. The error that you are seeing is because the default Designer layout leaves out the wires between the Deinterleave and the Interleave modules, so that you can fill that space in with your own ideas! Simply connect these modules together, or delete them and wire the first Type Convert to the second Type Convert. The key here is that if there are input/output pins left unconnected in a layout, than it is considered incomplete and will not run. Hope this helps!
5:37pm
Hi Andrew
Thank you for the explanation.
“The error that you are seeing is because the default Designer layout leaves out the wires between the Deinterleave and the Interleave modules, so that you can fill that space in with your own ideas! Simply connect these modules together, or delete them and wire the first Type Convert to the second Type Convert. The key here is that if there are input/output pins left unconnected in a layout, than it is considered incomplete and will not run.”
But I do not know how to do this???
Can you assist?
Thank you
D
10:12am
Hello, yes I can definitely assist! In short, the problem is you can't have any floating modules or partially wired modules in the layout. All module input and output pins must be wired to something.
Check out Episode 5 of our training on this page https://dspconcepts.com/audio-weaver-training
It goes over how to use Audio Weaver Designer, and how to build your own layouts. There are other episodes that will also be helpful for your future endeavors.
-Andrew P
3:21am
Hi Andrew, - Thank you. All great stuff
I watched the first 5 Episodes. Great…a little over my head. But I see why I have the error, but I have no way of knowing how to fix it.
It would be nice to get the first lesson working????
It may have something to do with my Audio (???). I am using a USB DAC and I can also see the STM32 in the sound panel. I have USB DAC selected, but there is also no sound with the STM32 selected as default. But the status bars are going up and down on the Realtek Digital output – that is not connected to anything????
Then in the time it took me to get some headphones…the rising status bars disappeared, and I could not get them back??
I closed the programme and reopened and now I have 8 inputs and 4 outputs and no way to make the connections???
Looks like I am going wrong somewhere???
Just to be honest here. I am a small bloke in the Australian bush, just trying to fine tune his stereo. I would like to have a 2- or 3-way crossover and some DSP. Just to be totally upfront. I am not working for anyone who is connected to audio. I am the OWC Watch company – www.orangewatchcompany.com, only a 1-man operation and still finding it tough….
Makes it hard with the time zone. I am in Australia.
D
2:39pm
Hello again, see the answers to your questions in lined below...
Hope this helps, and we appreciate your interest and patience!
-Andrew
6:34pm
Hi Andrew,
Great to get your response. Thank you.
I used the right click and changed the number of channels to 2 each side…But it did not work:
See Capture 2019-10-05-001.
I did the exercise (as an aside, my wires seem very thick???) and not music from my speakers or the headphones. I changed AWE Server to Native and I changed the windows to all the configurations.
See Capture 2019-10-05-002.
Thanks for the explanation of the 4 in and 8 out. In summary it is to go with all the things on the board. But for normal use (i.e. stereo) just 2 in and 2 out.
Looks like 1 step forward and 2 back.
My gut tells me I need to hear the music otherwise it is no go….
D
PS I cannot attach the screen captures. Sorry, I keep trying and nothng
4:30am
2019-10-08:
Thank you. And thank you for making the videos. (Obviously at a higher level than I).
I have been working with the programme all weekend and got very frustrated as I kept getting silence and many different errors.
I also noticed above and below your name (Andrew): “analog-passthrough.awd” Should I do something with this??
I know I am asking a lot, but I remain stuck on video 5 with no sound.
My timezone is also causing problems.
Thank you
D
12:27am
Hi Guys - still not understanding. It would seem the You Tube videos are old and I have a strange card (STM32769). I tried to read the 163 page manual and I got totally lost.
I would like some help. Thank you
D
10:48am
Hello again, lets take a few steps back and start by focusing on the "Native Target". The Native Target is basically just a way to run Designer layouts on your PC using your soundcard. You can configure to either play from a file (the piano music!), or take line in from your soundcard. Before you dive back in to the 769, lets get a layout running on the native target.
The relevant documents for your use are as follows...
https://dspconcepts.com/sites/default/files/audio-weaver-designer-users-guide.pdf
https://dspconcepts.com/sites/default/files/audio_weaver_stm32f769i_discovery_board_users_guide_2.pdf
Hope this helps!
