I am evaluating the STM version of AWE Designer and Core (running on the STM32F407 Disco board). I have received a layout file from Acoustics colleague that includes Controllable SOF Modules. In the design the gain of the controllable SOF module is changed based on previous processing of the audio signal.
This Module seems not to be available in the AWECore ST.
Is there a way to control the gain by other means?
I found the ParamSet module, which seems to have the necessary functionality, e.g. getting the processed signal on the input wire and writing the value to the "normal" SOF module gain. Does it make sense, would that work ?
best regards,
Witali
9:54am
Hi Witali,
The approach you've proposed using the ParamSet module is the best option given the modules available in Audio Weaver ST.
Michael
2:47am
Hi Michael,
thank you for your quick reply!
BR
Witali
