The custom module has the following matlab code in the matlab\my_new_module.m file:
add_array(M, 'test', 'int', zeros(1,3), 'parameter', 'test', 0);
M.test.guiInfo.label = ['t1;' 't2;' 't3;'];
add_array(M, 'param', 'int', zeros(3,1), 'parameter', 'param', 0);
M.test.guiInfo.label = ['p1;', 'p2;', 'p3;'];
add_array(M, 'demo', 'int', zeros(1,3), 'parameter', 'demo', 0);
M.demo.guiInfo.label = ['d1;' 'd2;' 'd3;'];
But only the three horizontal labels in the demo are displayed normally
6:04pm
I noticed that you used the "test" object for both the first and second arrays.
M.test.guiInfo.label = ['p1;', 'p2;', 'p3;']; <--- this line has commas between the elements
This doesn't directly answer your question but it might be part of the issue. Also check the commas between the elements as noted.
11:36pm
Thank you for your reply. I have modified the code as follows, but it still cannot display vertical labels and multi-page labels. It can only display horizontal labels on the last page.
