Hi
I'm using AWE Designer 8.2025.2.A_Standard. When I open an example then I see below errors
Then I check and don't see AlsaSource and Snapdragon Sink modules at all in this version
Could you please check which version I should use to have those ?
11:15am
Hi Minh,
You will need a special version of Audio Weaver to work with AWE-Q for the time being. What is your version of AWE-Q?
12:58am
Hi, gary
I have the same question with Minh, Please tell me how to obtain the AWE-Q tool. thanks
4:37pm
These modules are not package with Standard Designer versions and are instead packaged with AWE-Q Designer builds. AWE-Q is a separate tool from Standard or Pro versions of AWE Designer. I will reach out to you both via email to discuss acquiring AWE-Q.
9:10pm
hi, my email is gary-hui.wang@valeo.com, you can reach me by this email, thanks.
