We are finding that when we want to use the SOFCascadeHF module and we want to change the lowest
frequency that it can manipulate it has a tendency to get stuck around 38.4 Hz. We tried to change
it to 20 Hz but after closing and opening the properties of the module, it changes back to 38.4.
Is there a step that we are missing?
The AW version we are using is 5.16.B04 released around December 2016.
EE
4:58pm
Hi EE,
The problem you describe is a known bug in Designer having do with a disconnect between the properties window and the module. The module is actually calculating the frequency range based on the sampling rate of the system; (approximately) lowRange=SR/5000 and highRange=SR/2. The Min, Max, and Step variables in the property window are not currently being used in the actual frequency range.
We will release a fix in a future version.
