I am using 6.17.06 PRO. I am running on a Lenovo Think Pad. MATLAB Version: 9.0.0.341360 (R2016a). Intel HD Graphic.
I have a Dell monitor connected to my laptop. When I launch designer I pull the window to the larger Dell monitor. When I open an inspector it always opens on the left side of the laptop screen. I can move it over and everything seems fine but if I stop and restart the signal flow the inspector moves back to the left side of the laptop screen.
Is this a new feature or a bug?
3:02pm
Hey Darrel, Thanks for the report - we'll take a look!
3:31pm
Hello Darrel,
Thank you for letting us know about this issue.
In order for me to understand the problem I need to have your layout file. I need to know inspector for which module in the layout did you open?
Could you, please, provide this information in order for me to provide definitive answer.
Thank you
5:37pm
Here is a simple example:
Audio Weaver Designer is on my left screen. When I double click on a module the inspector opens on the primary screen.
I can drag it to the left screen and click play it stays on the left screen.
Now if I change the block size argument it immediately moves back to the primary screen
Changing any argument and hitting return sends it back to the primary screen.
I have two computers with audio weaver installed. I see the problem on both. The Lenovo is running Windows 10, the Dell is running Windows 7.
1:44pm
Thank you Darrel for providing the information about the issue. We will analyze the information and get back to you as soon as the solution is found.
