Hi. I've been modifying the SAM71 schema and board to expose the i2s and ssc to 3 headers - the "SAM V71 Audio Edition". Attached. I have culled a lot from the original board.
The dev board used one of the SSC inputs as a clock source from the CS2100 PLL.
Can you recommend another pin suitable to accept this AVB audio recovered clock input to that I can keep the SSC pins unconnected? Currently connected to PA22 (RK).
3:55pm
Hi David,
It seems like you're working on an interesting project with the SAMV71. Unfortunately, your question goes beyond what our support team can provide for help with the reference SAMV71 BSP integration. I would recommend studying the data sheet and the User Guide for the SAMV71, and of course scouring the internet for similar projects.
Good luck!
