I have been studying the pdf file Audio weaver Server Command Syntax that is found in the Docs folder of the AW installation.
I have multiple installations and I have quickly reviewed files from AWE 5 and AWE 6.1.06 (latest). On the PFID listing, I can only find
command with ID = 55. However, when I look into my target files, I observe that PFID definitions go all the way up to 86 (PFID_WB_GetMute).
Can I request a newer pdf if it is already available ? Thank you.
Regards,
Emilson Enrique
Danville Signal Processing, Inc.
10:03am
Hi Emilson,
We've been recently working on updating this document. I'll email you a copy of our current draft, and we will get the polished document on the website when we release the next Designer version.
Axel
