Given a multi-channel application, Is there a straight forward means to time align the channels? Case in point, assume two channels.
Channel 1 is processing is a simple Compressor/limiter. Channel 2 is the exact same compressor/limiter with the addition of a 5 band parametric EQ with Low Pass and High Pass filters. In a live sound application we want to make sure that sounds arriving simultaneously at the DSP's inputs appear at the outputs in sync. Does Audio Weaver have a way to handle this?
Dane Butcher
Symetrix Inc.
6:30pm
Hey Terry
We usually use delay module to time align channels. The delay modules can be tuned to compensate for the specific difference in delay between the paths. We have modules that delay by integer samples, fractional samples, and milliseconds. They can all be found in the "delay" folder of the module palette.
Let us know if there's anything else.
