Trouble with AWE_BSP_stm32l496_s1.4-Demo-Project on STM32L469D-DISCO-Board
4 posts / 0 new
TT
Last seen: 3 weeks 4 days ago
the Example on Disco-Board doesn't run.
Equipment/Docs:
-Audio_Weaver_Designer_7.A.0.8_STMicro.exe
-AWE_BSP_stm32l496_s1.4_Installer.exe
-STM32L469D-DISCO-Board
-ST-LINK-Utility V4.4.0.0.
-Audio Weaver STM32L496 Discovery Board Users Guide.pdf
I've flashed the "STM32L496_Discovery_SW4STM32.bin"-Binary using ST-LINK-Utility.
The Audio/HID-Devices appears in the Device-Manager.
The AW-Server says "can't connect"
I have compiled the Example with GCC.
The App hangs while Initializing (in AWMain.c "awe_fwInit(&g_AWEInstance);")
The Main-Loop will never reached!
What's wrong?
Is there a Version-Conflict.
The Binary should run out-of-the-Box.
a little frustrated...
Kind Regards
Thomas
Axel Nilsson
Last seen: 6 days 4 hours ago
Hi Thomas,
This problem is often caused by USB cables that supply only power, not data & power. Please try with other USB cables that you know can transfer data & power.
Have you also tried flashing the other .bin files (EWARM and MDK-ARM)? If those work for you but the SW4STM32 .bin does not, then please let us know.
Thank you
TT
Hi Axel,
thanks for your advice.
USB-Cables are not the problem here.
As I wrote: The Audio/HID-Devices appears in the Device-Manager.
awe_fwInit() hangs...
The Issue:
The Disco-Board comes with a (fancy) preloaded App.
You !!! MUST !!! delete the external (QSPI)-Flash.
(with ST-LinkUtility)
Otherwise the AWE-Core crashes.
After that you can flash the bin-File (EWARM/MDK_ARM/SW4ST32 doesn't matter)
When I play audio the Sound is horrible. (pops and clicks)
The Mems-Mics doesn't work at all.
Is MEMS-Mic-Audio-In implemented?
I run "AudioCheck.awd", the CPU-Load is approx. 24%.
Is the STM32L4 to small for AW?
Other obscure behavior:
AW does not start when installed in "c:\Program Files\DSP Concepts\" for example
(splashscreen appears and thats all..)
Seems to be a long way to get familiar with AudioWeaver.
Kind Regards
Thomas
Chris Perry
After flashing the firmware image please unplug both USB cables and then plug them back in again.
When I flash the board using ST-Link, if I do not power cycle the board, I hear static in the audio output.
To test, I power-cycled the board by unplugging then replugging both USB cables.
I connected to this target using AWE_Server.
I then created a pass-through AWD in Designer by wiring the unconnected output pins of the deinterleave module to the input pins of the interleave module. I then hit the build and run button in Designer.
Next I checked the Windows volume control to make sure it was using "AWE Audio Class" device>
Finally I played an audio file using Windows MediaPlayer.
