FileSink behavior when path is not valid
3 posts / 0 new
EJing
Last seen: 1 week 1 day ago
What does the FileSink module do when when the specified path is not valid?  Does it just not created the file?
Also, is there an easy to way to specify a valid path for both Windows and Linux?
Andrew
Last seen: 5 days 12 hours ago
Yes you are correct that it does not create the file if the path is invalid.
The most simple way to have a valid path for both Windows and Linux would be to use "./" as the file path. This will place the output file in the same directory as the executable. So for Windows it would be placed in the "Bin\win32-vc100-rel" folder (where AWE_Server.exe) lives, and on Linux it would be placed wherever the application lives.
Hope this helps!
EJing
Thank you.
