How can I have Multiple tabs on Inspector window?
I have huge number of tuning parameters, So I wanted to split these parameters among the tabs of Inspector Window such that the Inspector should not be looks bigger and uncomfortable while tuning.
Thanks in Advance.
12:17am
Hello Prabhakar,
If I'm understanding your comment correctly, we don't currently have a tab view for inspectors. However, if you are referring to grouping your inspectors by subsystem tabs, that is possible. With the Inspectors you want to group open, you can navigate to the top menu in Audio Weaver Designer and click 'Inspector > Save Group'. This will prompt you to name your group of Inspectors. You can then repeat the process for other Inspectors groups. As you add groups of inspectors, you will see that when you click 'Inspector' in the top menu, the groups will be listed, making it easy to switch between groups. I hope this helps.
