I am an acoustics engineer at Triton Sys, Inc. I am trying to use the Total Phase Aardvark to connect my computer to the Analog Devices ADSP-21489 EZ-KIT.
I have been following the instructions to get this system working. However, after connecting the Aardvark to the ADSP-21489 board with some jumper cables and firing up Visual DSP++, there is no recognition of the device. I have installed and reinstalled the TotalPhase Driver, but that does not seem to help.
Also, it seems that the license key provided for the Visual DSP++ software provided when I bought the kit is only temporary, so this is somewhat time-sensitive.
Does the team have any familiarity with this use case, and if so, could it provide some support for me?
Thank you very much.
5:17pm
Hi Daniel,
Unfortunately the Engineer who did the integration for this capability (talking to the ADSP-21489 Ezkit BSP over SPI using Aarkvark) is not currently unavailable until next week. Can you can talk over RS232, which is one of DSP Concept's standard tuning interface?
11:23am
Hi Kevin,
I have been trying to get it to talk via a RS232 to USB cable, but no such luck so far. I will note that I have needed to use a null model mini adaptor to get the male RS232 to fit into the female connector on the EZ-KIT without interference from the threaded nuts on the cables and board, so Pin 9 doesn't seem to be communicating.
-Daniel
11:50am
Hi Daniel,
Thanks for the information. Let's take this offline, I'll email you shortly.
