AWE Designer
Log in to post new content in the forum.
Topic / Topic starter | Replies | Last post | |
AWE Designer - missing wiring by Mike Ir. » Tue, 03/02/2021 - 4:20pm |
2 |
by Mike Ir. Wed, 03/03/2021 - 10:46am |
SYS_out: saving two different mono tracks rather than a stereo signal with two channels? by Mike Ir. » Fri, 02/26/2021 - 1:16pm |
1 |
by DSPC Kevin Fri, 02/26/2021 - 8:07pm |
multiplying output of WOLA fwd filterbank with complex vector by Mike Ir. » Thu, 02/18/2021 - 6:14pm |
2 |
by Mike Ir. Fri, 02/19/2021 - 9:49am |
adding function by Mike Ir. » Tue, 02/02/2021 - 1:54pm |
1 |
by DSPC Kevin Tue, 02/02/2021 - 3:27pm |
FIR module no sound by Sjef » Sun, 01/24/2021 - 4:48pm |
7 |
by DSPC Kevin Fri, 01/29/2021 - 2:50pm |
Controlling sub-systems fractional delay module from top level by Mike Ir. » Mon, 01/25/2021 - 1:38pm |
1 |
by DSPC Kevin Mon, 01/25/2021 - 4:02pm |
Feedback combfilter and allpass - sample by sample computing by Henrik » Wed, 01/20/2021 - 3:11pm |
3 |
by DSPC Kevin Thu, 01/21/2021 - 11:14am |
Strange currentDelay-Value of Sample Delay by Henrik » Fri, 01/15/2021 - 9:46am |
6 |
by DSPC Kevin Tue, 01/19/2021 - 4:29pm |
Which module to use for feeding variable between 0-0.5 or constant 1? by Mike Ir. » Thu, 01/14/2021 - 10:21am |
3 |
by DSPC Kevin Fri, 01/15/2021 - 2:55pm |
Adding multiple input in audio weaver designer? by etoz » Wed, 05/16/2018 - 9:19am |
8 |
by DSPC Kevin Wed, 01/13/2021 - 7:56pm |
Measuring Time between Impulses by Henrik » Tue, 12/22/2020 - 9:05am |
1 |
by DSPC Kevin Tue, 12/22/2020 - 11:21am |
Does the FIR filter use the SHARC FIR accelerators ? by dspdude » Sun, 10/15/2017 - 8:37pm |
3 |
by DSPC Kevin Fri, 12/04/2020 - 6:49pm |
Measurement: inner matrix dimensions must agree by John Brodie » Mon, 11/02/2020 - 11:55am |
1 |
by DSPC Kevin Tue, 11/03/2020 - 6:14pm |
AWE Designer ST version 8.B.1.5.C Audio Path error - cannot be reolved using configuration tools within Designer by gipsyblues » Sat, 10/24/2020 - 2:00am |
3 |
by DSPC Kevin Wed, 10/28/2020 - 10:37am |
postShift in Multiplier by John Brodie » Thu, 10/22/2020 - 5:45pm |
1 |
by DSPC Kevin Fri, 10/23/2020 - 1:33am |
How to configure parameters/ by Jacky » Wed, 10/07/2020 - 9:11pm |
1 |
by DSPC Kevin Thu, 10/08/2020 - 6:30pm |
Selecting core to run on from AWE Designer by jahall_128 » Fri, 10/02/2020 - 6:59pm |
1 |
by Chris Perry Sat, 10/03/2020 - 7:34am |
Is there a way to take an effect of clicking run button in the AWE designer GUI using a command in MATLAB by jungsuklee_6260 » Tue, 09/15/2020 - 1:51am |
5 |
by DSPC Kevin Thu, 09/17/2020 - 7:18pm |
Pop up menus going off screen by gelmont » Wed, 09/16/2020 - 9:14pm |
2 |
by gelmont Thu, 09/17/2020 - 12:09pm |
Errormessage: "STATUS must be one of the following: 'active', 'muted', 'bypassed', 'inactive' ", but no specific error to be found? by visuelle-musik » Sat, 09/05/2020 - 2:48pm |
2 |
by visuelle-musik Sat, 09/05/2020 - 3:41pm |
Virtual Soundcard During Development? by John Brodie » Wed, 08/26/2020 - 8:48am |
1 |
by DSPC Kevin Wed, 08/26/2020 - 11:30am |
Using DCSourceInt to select between different submodules? by shaikath » Fri, 08/21/2020 - 4:23pm |
1 |
by DSPC Kevin Fri, 08/21/2020 - 6:26pm |
Very bad audio quality when testing designs by Yair Raz » Sat, 03/28/2020 - 1:54pm |
5 |
by DSPC Kevin Thu, 08/20/2020 - 4:06pm |
Cannot Connect to ADSP-21489 EZ-KIT by Daniel » Tue, 08/18/2020 - 4:04pm |
3 |
by DSPC Kevin Wed, 08/19/2020 - 11:50am |
New line in Text Annotation by Cole » Mon, 04/13/2020 - 2:37pm |
6 |
by DSPC Kevin Wed, 08/19/2020 - 10:46am |
